TankJet 360 Fluid Driven Tank Cleaner from Spraying Systems Co. is equipped with a dual- or triple-nozzle hub and high-impact solid stream nozzles that rotate 360° in horizontal and vertical planes.
The TankJet 360 Fluid Driven Tank Cleaner is equipped with a dual- or triple-nozzle hub and high-impact solid stream nozzles that rotate 360° in horizontal and vertical planes. The rotation creates a crisscrossing pattern to thoroughly clean tanks up to 100 feet in diameter and remove the stickiest of residues. In addition, high-impact cleaning results in shorter cycle times so tanks are returned to service more quickly. TankJet 360 is available with three gearbox designs: food-grade, oil-lubricated or flow-through.
