The Cat5/5e/6 Lightning protectors are designed to protect your investment in expensive communications equipment. With multiple styles to choose from, ranging from standard to high power models, these lightning protectors are designed for use in both commercial and industrial network installations.
Versions include indoor and outdoor, as well as compact weather resistant models the Cat5/5e/6 Lightning protectors are available from single-port passive injectors, injector kits, and outdoor midspan/injectors.
In addition to theCat5, Cat5e, and Cat6 data-line lightning and surge protectors the PoE injectors with integrated surge protection can be used with IP cameras, access servers, outdoor routers, and other IP enabled devices.
L-Com
https://www.l-com.com
