Single range transmitter
The SITRANS P250 is a compact, fixed-range transmitter for measuring differential pressure of liquids and gases. The differential pressure is detected with a ceramic sensor and converted by an amplifier into an output current of 4 to 20 mA, or an output voltage of 0 to 5 or 10 VDC. The output current and voltage are linearly proportional to the input pressure.
The SITRANS P250 is a compact, fixed-range transmitter for measuring differential pressure of liquids and gases. The differential pressure is detected with a ceramic sensor and converted by an amplifier into an output current of 4 to 20 mA, or an output voltage of 0 to 5 or 10 VDC. The output current and voltage are linearly proportional to the input pressure. It also features a compact design, including a sturdy stainless steel enclosure and ceramic sensor.
Siemens Energy & Automation www.sea.siemens.com
