The Easylock™ shaft collars, for high speed converting and winding applications, allows users to adjust the holding force from 90 to 1,124 pounds.
The Easylock™ shaft collars, for high speed converting and winding applications, allows users to adjust the holding force from 90 to 1,124 pounds. Easylock shaft collars with positive release are designed to reduce downtime to help maintain consistent production rates. The quick-release feature makes Easylock collars well suited to high volume production where frequent changeovers of shaft-mounted tools, reels/spools and other objects are required.
Amacoil
