See ways create and formulate a plan to keep your workers and plant safe.
The Imperial Sugar dust explosion of 2008 was a tragic reminder of the potential for common food processing ingredients to cause unneeded loss of life and property in a food plant.
While it’s not feasible to ditch dusty ingredients like sugar, flour and cornstarch in most food processes, you should be aware of the danger particular ingredients create and formulate a plan to keep your workers and plant safe.
Common ingredients that create dust hazards
Whether you’re using baking powder as an ingredient or packaging raw sugar for sale, handling particulate solids creates hazards. Before minimizing the risks those hazards pose, you need to know what ingredients have the potential to create dust explosions:
- Animal feed
- Baking ingredients (baking soda, baking powder)
- Cocoa
- Coffee (roasted, ground and soluble)
- DDGs (distillers dried grains)
- Flour
- Nut dust
- Nutritional powders
- Pollen
- Powdered flavorings
- Powdered milk
- Soybean (processed)
- Starches
- Sugar.
Keep in mind, this is not an exhaustive list of every ingredient that could pose a dust explosion threat. Metal shavings, plastic shavings and sawdust are just a few non-food materials that can also create massive explosions in high enough concentrations.
The explosive potential isn’t in the flammability of the materials themselves — it’s in the high surface area of the dust particles.
While wood is flammable, it takes a few minutes and some kindling to light up a log, which could then take hours to burn to ash, depending on its size. A grain of sawdust from the same log, however, takes a small amount of heat or a little static shock to ignite — once it’s on fire, it flashes to ash in an instant.
Since the burn happens on the surface of the material, which is exposed to oxygen, the higher the surface area, the higher its explosive potential. In an enclosed space where dust particles accumulate, a single ignited particle could cause a chain reaction that leads to a percussive explosion with the potential to crumble concrete floors and rip doors off their hinges.
Identify and control dust sources
To put dust control measures in place, you’ll need to figure out where the hotspots in your facility are located.
Wherever there is mechanical transfer (like a conveyor belt, as we saw in the 2008 Imperial Sugar incident) or pneumatic (pressure conveyors) transfer of powder ingredients or finished products, there is a risk of dust building up, especially near line connections and dispensers. Make sure these systems are designed to handle the amount of material flowing through them to avoid internal accumulation and potential blockages.
Where powder ingredients are added by hand, there is also a risk of airborne dust particles escaping to nearby surfaces.
As dust gets into the air from transfer and production processes, it accumulates on top of equipment, rafters, silos and storage bins.
A dust collection system should be in place to remove airborne particles before they have the chance to settle on surfaces in your plant. The system should be calibrated for the correct volume and particulate size to prevent clogs in the dust collector. The filter material should also be specifically selected for the ingredient running through it.
The location of dust collectors is paramount to the safety of your plant and personnel. Vacuum hoods and point source vacuums should be placed in areas where material is added, transferred or packed — where loose particles will most likely escape.
The dust collection system should be configured to release any built up or vented dust outside the process area in the event of a system failure.
Check equipment NEC hazard ratings
According to the National Electrical Code (NEC), Class 2, Division 1 hazards are areas where combustible dust is present under normal operating conditions, while Class 2, Division 2 hazards are defined as areas where combustible dust is not present under normal operating conditions.
A Class 2, Division 1 space could be the area where sugar is transferred into an open container, or the storage silo where it’s kept. A Class 2, Division 2 space could be the area where a pneumatic transfer tube carrying cocoa powder runs through, where a leak or rupture could lead to hazardous levels of dust.
Electrical equipment used in the vicinity of these spaces should be rated to operate under these conditions.
On a recent bakery project, the dough mixers had a warning label stating devices plugged in within a 10-foot radius around the mixers must be rated Class 2, Division 2. The space was designed to keep lighting fixtures and other easily moved devices that weren’t Class 2, Division 2 outside the danger zone to save costs. Generally, equipment rated for more hazardous conditions is more expensive than non-hazard rated versions.
Keep good housekeeping habits
Even if you make every effort to capture and control dust in your plant, particles are bound to escape over time and eventually build up on equipment in processing areas. Good housekeeping measures are the only way to keep this accumulation at bay.
Educate workers in the processing area about dust hazards and the best ways to handle particulate ingredients during production. Make sure safety and cleanliness is part of your workforce’s culture — your employees will appreciate the measures you take to keep them safe by enforcing high standards on the job.
Additionally, designing and installing a central vacuum system in your facility makes it easy for operators and sanitation workers to regularly vacuum hard to reach areas like corners, rafters and the tops of storage bins without having to drag around bulky cleaning equipment.
A central vacuum system makes it easy for spills to be quickly cleaned on the production floor while minimizing the risk of a traditional floor vacuum malfunctioning and possibly spilling even more dust in your plant.
Instilling knowledge, cleanliness and safety in your workforce while providing them with the tools to keep them safe will protect your employees, business and brand.
This article originally appeared on Stellar’s Food For Thought Blog. Stellar is a CFE Media content partner.
