Tool aligns V-belt pulleys SheaveMaster mounts magnetically to the face of a pulley.
SheaveMaster mounts magnetically to the face of a pulley. A permanently calibrated laser beam fans out, striking three magnetic targets on the opposite pulley and measures angular, offset, and twist misalignment of the drive. The device can also be used on chain drives. It only requires one person to operate and can be used indoors and outside. Ludeca, Inc.; www.ludeca.com
TO VOTE, WRITE 9 ON BALLOT
For more information, circle 9 on card
Pumps easily add accessories
Global Hushh 2000 Series electric motor driven pumps can be configured as single or two stage. The modular design allows easy installation of various valve configurations and optional accessories, such as return line filter, heat exchanger, float/temperature switch, and pressure switch. Accessories are added externally; the pump is not disassembled. The pump provides pressure up to 10,000 psi. Enerpac; www.enerpac.com
TO VOTE, WRITE 11 ON BALLOT
For more information, circle 11 on card
Software solves hydraulic problems
HydroPack 2000 contains 31 hydraulic/ fluid mechanics computer programs, each with a brief description and sample calculation. The programs are easy-to-use and can switch between British and metric units. Sample programs include pressure loss through valves, friction head loss in pipes, actuator speed, centrifugal pump head, and flow rates of water. Unik Associates; www.engineering-unik.com
TO VOTE, WRITE 60 ON BALLOT
For more information, circle 60 on card
Belt increases capacity and cuts maintenance
Poly Chain GT 2 belt is ideally suited for synchronous drives less than 500 rpm and horsepowers up to 1200. The belt transmits up to 30% more power than its predecessor does. This version permits the design of more compact, lighter weight drives. When combined with Taper-Lock sprockets/bushings, lifetime parts replacement and maintenance costs are reduced. The Gates Rubber Co.; www.gates.com
TO VOTE, WRITE 138 ON BALLOT
For more information, circle 138 on card
Seal stops leakage during maintenance
Inflatable Safety Seal is a pneumatic, inflatable product used for static shaft sealing. When used with a mechanical seal, this device can be inflated to provide a positive seal, preventing product leakage if the primary shaft seal fails. The inflated seal also prevents product loss during seal maintenance. It is available in shaft sizes from 2.75-8 in. A. W. Chesterton Co.; www.chesterton.com
TO VOTE, WRITE 168 ON BALLOT
For more information, circle 168 on card
Bearings’long life reduces maintenance
Explorer spherical roller bearings last up to three times longer than comparable products under carefully controlled endurance tests. This highly durable bearing is dimensionally interchangeable with existing ISO-design spherical versions. Replacing these bearings reduces maintenance costs and increases load capacities of equipment. SKF USA, Inc.; www.skf.com
TO VOTE, WRITE 180 ON BALLOT
For more information, circle 180 on card
