Two new water-soluble Multan metal removal lubricants are formulated to generate minimal foam and be used continuously for years with minimal biological degradation. The Multan B 236 and B 414 are semi-synthetic metal removal fluids for machining and grinding ferrous and non-ferrous alloys. These lubricants are designed for applications where soft water or process requirements make foam control...
Two new water-soluble Multan metal removal lubricants are formulated to generate minimal foam and be used continuously for years with minimal biological degradation. The Multan B 236 and B 414 are semi-synthetic metal removal fluids for machining and grinding ferrous and non-ferrous alloys. These lubricants are designed for applications where soft water or process requirements make foam control difficult. It will act as a universal lubricant on soft metals and more exotic alloys.
Henkel Corp. , www.henkelna.com
