| Loosening bolts Problem: Loosening hard-to-unscrew bolts and screws is a challenging chore. Is there an easy way to get the stuck bolts moving? Solution: Place a properly sized drive punch in the center of the bolt head (or cup if SHCS bolt) and use hard tapping with a hammer. The “shock” created unsettles the stubborn bolt and removal is almost certain. Contributor: Luc Raeckelboom Curing Engineer, Michelin Tire Co., Greenville, SC; 864-458-1212 List of Tips & Tricks |
| Plant Engineering | |
