Tight moves
Problem : A piece of equipment close to a column or other stationary object needs to be moved closer. The spacing is too close to use a come-along.
Solution: Make a “Spanish windlass.” Pass a length of rope around both objects and tie the ends together. Place a bar or handle through the center of the loop and twist the opposite sides together. The twisted rope creates considerable pulling force for a short distance.
Contributor : D.E. Burgess, Phoenix, AZ
List of Tips & Tricks
Plant Engineering
