Instruments and Controls – 2004-09-10
Inline flowmeter
Series 730 Accu-Mass flowmeter measures flow rates of noncorrosive gases from 0.5 to 50 SCFM and provides a linear output signal proportional to total gas mass flow rate. This direct mass flow monitoring method eliminates the need for separate temperature and pressure inputs, improves measurement accuracy, and helps reduce system cost.
Sierra Instruments, Inc. sierrainstruments.com Write 309 on PE card
Humidity-logging thermometer
Micro Humidity Logging Thermometer sends alarm messages by email or phone. If logger is connected to a computer during real-time monitoring, an email error report can be sent either on the first occurrence only, or as often as once every minute as long as alarm condition exists. If connected to a phone line and modem, unit sends a 6-digit message that can go to a pager.
Telatemp Corp. telatemp.com Write 310 on PE card
Modular instrumentation interface
Kenmac series 85 is a modular instrumentation interface and mounting system. Interface features 2 and 4-valve manifolds for pressure and DP measurements, instrument mono-flanges for isolation and vent functions, self-venting single and double purge blocks, electric heaters, steam trace blocks, seal pots, filling connector, and protective shade.
Swagelok Co. swagelok.com Write 311 on PE card
Clamp meter
Industrial clamp meter series is available in 400-A, 600-A, and 1000-A models. The 600-A and 1000-A models feature an LCD display built into the bottom of the testers, enabling electrical workers to view the display from virtually any angle. Other features include large, tapered jaws and a wire-separating hook tip, high-voltage indicator, motor and drive troubleshooting mode, and true RMS.
Ideal Industries, Inc. testersandmeters.com Write 312 on PE card
Sensor tester
Sensor Tester tests hydraulic motor speed sensors and pulse detectors. Unit is designed to test Hall effect and optical sensors. It tests most low-voltage (4.5-24 Vdc) sensors that use make-and-break contact pulse sensing.
White Hydraulics, Inc. whitehydraulics.com Write 313 on PE card
Data acquisition
instruNet World Plus is a data acquisition software program for Windows 95/98/NT/2000/XP that enables users to digitize, plot, control, analyze, and save to disk A/D, D/A, and digital I/O data from instruNet hardware. It enables users to define their own instrument front panel with buttons, popup menus, edit fields, dynamic text, text editor regions, and waveform graphs.
Omega Engineering, Inc. omega.com Write 314 on PE card
Photoelectric sensors
OG 90 photoelectric sensors are designed with right-angle lenses for applications with limited mounting space. Sensor features an 18-mm stainless steel housing, preset sensing ranges, and visible red beam that facilitates sensor alignment during installation. Units are available with through-beam, polarized retroreflective, and background suppression models.
ifm efector Inc. ifmefector.com Write 315 on PE card
Toxic gas detector
TS4000 intelligent toxic gas detector is a microprocessor-based transmitter designed to monitor toxic gases or oxygen deficiency and provide status indication and alarm outputs. Detector features remote mounting, dual redundant Modbus communications, 8-A relays, 3-digit display, 4-20-mA output, and indication of remaining sensor life.
General Monitors generalmonitors.com Write 316 on PE card
