Industrial fire and gas protection controller for hazard monitoring, control
Honeywell's HS81-HS controller is an industrial fire and gas protection controller system designed for hazard monitoring and control at industrial sites and can interface with plant safety and control systems through multiple protocols.
Honeywell’s (NYSE: HON) HS81-HS controller is an industrial fire and gas protection controller system designed for hazard monitoring and control at industrial sites, the solution is ideal for on- and off-shore oil and gas facilities, petrochemical processing plants, aircraft maintenance hangars, ships/floating vessels, mission-critical facilities, and military locations. The HS81-HS Controller performs flame, smoke and gas detection and extinguishing/agent release, and can interface with plant safety and control systems through multiple protocols. It also features a unique "hot swap" capability for the replacement and auto-configuration of CPUs and power supplies without performing a critical system shutdown. The new HS81-HS controller carries SIL2 and SIL3 ratings in addition to meeting NFPA-72 and EN-54 requirements. It is available with a line of compatible flame, gas, smoke, and aspirating detectors.
Honeywell
www.honeywell.com
– Edited by CFE Media. See more Control Engineering process safety products.
