Series SHG 316-stainless steel hydraulic cylinders are corrosion- and bacteria-resistant and provide 3,000 psi hydraulic capabilities. The line features rounded corners on the head and cap and a clean profile body with tie rods, self-regulating cushions, an electro-polished cylinder exterior, an integral gland with a food-grade wiper seal and standard PTFE piston seals with non-metallic piston ...
Series SHG 316-stainless steel hydraulic cylinders are corrosion- and bacteria-resistant and provide 3,000 psi hydraulic capabilities. The line features rounded corners on the head and cap and a clean profile body with tie rods, self-regulating cushions, an electro-polished cylinder exterior, an integral gland with a food-grade wiper seal and standard PTFE piston seals with non-metallic piston wear band. Stat-O-Seal washers under bolt heads for protection against contamination and assembly with H-1 rated lubricant.
Parker Hannifin Corp. : www.parker.com/cylinder
