How to manage the intersection of safety and asset management
By beginning with the end in mind and integrating engineering disciplines into the safety framework, leaders can transition from reactive reporting to a state of proactive intelligence and operational resilience.
Learning objectives
  • Understand the symbiotic relationship between equipment performance and human safety, specifically how reducing unplanned downtime and emergent work directly lowers the probability of recordable incidents.
  • Learn to use visual diagnostic tools like injury heat maps to identify risk clusters and concentrations of injuries and severity and drive technical change through cross functional collaboration.
  • Develop strategies for implementing reliability by design through early collaboration with OEMs to ensure standardized maintenance and safety protocols are established before startup.
Safety insights
  • Modern manufacturing excellence requires a fundamental shift where safety and asset management are no longer treated as separate silos but as two sides of the same coin.
  • By integrating reliability engineering into a cohesive asset management strategy, leaders can transform chaotic, reactive environments into predictable systems that inherently prioritize worker safety.
The resurgence of domestic manufacturing in 2026 represents a pivotal moment for industry leaders. As onshoring brings production back to the United States, plant engineers are entering a new golden age for the sector.
However, this shift requires more than just moving physical assets; it demands a fundamental mindset shift in how manufacturers approach the intersection of safety and asset management.
For a manufacturing leader, the nonnegotiable requirement is to begin with the end in mind. This means designing for reliability from the very first day to ensure that operational strategies are integrated not merely efficiently, but inherently safe. We are no longer in an era where we can afford to fix things after the process is already running; the stakes, both human and financial, are simply too high.
Balance reliability and safety
Historically, a wall existed between the engineering office and the safety department. This divide often relegated environmental health and safety (EHS) to a reactive role that focused almost exclusively on incident reporting and compliance after a tragedy had already occurred.
In a world-class manufacturing environment, this siloed approach is a liability. Real operational resilience is achieved only when safety and reliability are viewed as two sides of the same coin. By integrating engineering and reliability work into a single cohesive strategy, it is possible to transform a facility’s performance in ways that were previously thought impossible.
For example, this transformation took shape within the building products sector. By combining traditional engineering with reliability engineering, Life Cycle Engineering helped a large-scale operation grow its asset availability from a struggling 55% to 95%. More importantly, this transition drove a staggering improvement in safety. Plant managers saw the facilityโ€™s total recordable incident rate drop from 11 down to 1.8. These are not just numbers on a page; they are people going home whole because the leadership decided to take the physical risk out of the hands of the team members through better engineering.
Safety is essentially a function of predictability. When a machine operates as intended within its designed parameters, the risk to the operator is minimized. Conversely, the most dangerous moments in any plant occur during unplanned downtime or during emergent/reactive work. When a critical asset fails unexpectedly, the resulting pressure to resume production creates a chaotic environment.
Figure 2: Safety and reliability are two sides of the same coin; an integrated approach moves the facility from chaotic, reactive environments to a state of predictable, system-wide safety. Courtesy: Life Cycle Engineering
In that chaos, the human element is most vulnerable. Rushed decisions, bypassed protocols and the sheer physical stress of a breakdown are the primary ingredients for workplace injuries. A predictable environment is, by definition, a safe environment. The most successful transformations occur when the maintenance and safety departments stop seeing themselves as separate entities with competing goals and instead realize they are working toward a single outcome: an uninterrupted, risk-free production flow.
The power of visual risk mitigation
To move from a reactive culture to a proactive one, leaders must embrace visual data that is gathered from their asset management system as their primary diagnostic tool. Never underestimate the power of your own eyes and the clarity that well-constructed data visualization can provide.
One of the most effective tools in this transition is the use of injury heat maps. By overlaying safety trends directly onto maintenance performance data, organizations can identify exactly where risks are concentrated within a production process.
These maps provide a geographic and operational view of where recordables and first-aid incidents occur. They allow cross-functional teams โ€” including engineering, EHS and operations โ€” to see patterns that would remain hidden in a standard spreadsheet.
For instance, a heat map might reveal a cluster of minor lacerations or strains at a specific assembly point. This is an early warning system. Rather than simply instructing employees to be more careful, which is a reactive and often ineffective approach, the engineering team can step in to eliminate the underlying risk. This might involve using technology to automate a hazardous task or re-engineering the workflow to remove the human element from a potential point of injury.
This evolution is best captured in a multiyear transformation map. Improving safety and reliability is not an overnight task; it requires a focused plan that prioritizes and aligns the organization on the most critical aspects of the operation. As the organization moves from reactive to proactive maintenance, teams will see a measurable, positive shift in the performance. A plant will realize more planned work and fewer emergency break-in events. This shift is the hallmark of a mature asset management program.
Standardizing excellence, safety with OEM collaboration
As manufacturing returns to the United States, plant managers and safety experts have a unique opportunity to implement process design for reliability. With the global supply chain shifts of 2026, we are no longer at the mercy of fragmented overseas production.
The focus must be on working with original equipment manufacturers (OEMs) to ensure that safety, maintenance and reliability and operational care are packaged and delivered for the equipment before it is even turned on. The conversations should happen during the design and procurement phase, not six months after the machines have been bolted to the floor.
While an OEM may produce world-class technology, it may not be the right partner if its maintenance and reliability packages are inadequate. To bring in industry-leading technology, bring in a package that helps the workforce maintain and operate it safely from Day One. This means demanding detailed maintenance logic, standardized operating procedures and pre-packaged training materials as part of the capital investment. When reliability is designed from the start, managers significantly reduce the organizational risk associated with equipment failure.
Protecting the IP
In the modern manufacturing landscape, an organization’s secret sauce is no longer just the final product it ships. The true value resides in the specific operating parameters and sound maintenance and reliability package that are defined for the production environment. This internal intelligence is developed through years of engineering and consistent observation of equipment performance.
Figure 3: Using advanced asset management systems, cross-functional teams analyze visual data to proactively eliminate underlying technical and operational risks on the plant floor. Courtesy: Life Cycle Engineering
Protecting this intellectual property is essential for maintaining a competitive edge in an increasingly automated world. While technical platforms provide the speed and precision necessary to manage complex maintenance schedules, the foundational strength of a facility lies in the maturity of its predictive logic.
By analyzing equipment trends and sensor outputs, teams can identify early indicators of wear and potential failures long before they result in a critical shutdown. This foresight allows for planned intervention, which prevents the catastrophic failures that endanger both the machinery and the employees.
However, these predictive frameworks are only as good as the information they receive. Achieving high data quality is a cultural mission rather than a technical one.
Technicians must be encouraged to move beyond a checklist mentality. Cursory inspections and operator care tasks the practice of signing off on a task without performing it โ€” cannot be accepted. This requires a cultural shift where the individuals who understand the equipment most intimately are the ones driving the proactive intelligence of the entire company. This data is the lifeblood of the modern plant. Protecting it ensures that operational advantages cannot be easily replicated by competitors.
Using change management to achieve safety
While technical infrastructure and digital monitoring are crucial, safety remains a holistic concept that includes people as much as technology. Delivering technical change requires a deep focus on organizational change management. Change management methodologies ensure that the human element is not left behind during a technological shift. Leaders must foster a culture of ownership where employees at all levels feel empowered to identify and mitigate impending risks.
This ownership is built through transparency and functional partnerships across departments. When operators are involved in the reliability process, they transition from merely using a machine to caring for an asset. They become the first line of defense, identifying strange noises, smells or minor leaks before they escalate into something much worse.
This shift in perspective is the goal of a world-class asset management program. It moves the organization away from a culture of perfunctory compliance toward one of genuine engagement and continuous improvement.
Quantifying the economic impact
The financial return on this investment is clear. Beyond the reduction in injuries and the associated costs, a proactive reliability program can significantly increase the bottom line annually, often yielding double-digit percentage savings in maintenance and operational expenses. A rigorous focus on asset management can drop significant savings annually to the bottom line for a single facility. When a plant operates at 95% availability, it is not just more productive, it is more cost-effective. The need for emergency parts shipping, overtime for reactive repairs and the high cost of replacement equipment are all significantly reduced.
By extending the life cycle of assets, companies can prioritize capital planning and spending on growth and innovation rather than constantly fixing what is broken. This financial stability provides the resources necessary to continue investing in safety and technology, creating a virtuous cycle of improvement. In 2026, the companies that thrive will be those that treat their maintenance budget as an investment in resilience rather than a necessary evil.
Integrate safety, asset management from the start
As we look toward the remainder of 2026 and beyond, the message for manufacturing leaders is clear: the costliest way to address safety, quality and productivity risks is to fix them after the operations are already running. The organizations that will thrive in this new era are those that integrate safety and asset management into a single, cohesive strategy from the very beginning. This requires a commitment to partner with the right OEMs, capturing and using data for decision-making, a focus on effective engineering and a dedication to cultural change.
Ultimately, the goal is to create an organization that learns. Every work order, every safety incident and every sensor alert should be a data point that informs the operation to take actions and continuously improve. When these feedback loops are in the organizational DNA, a facility can achieve true operational resilience. Plants become capable of anticipating challenges before they manifest as crises. This is the future of manufacturing โ€” a state where intelligence drives action and where the safety of every employee is guaranteed by the reliability of the system they operate within.
Bruce A. Wesner, CRL, Life Cycle Engineering, Charleston, South Carolina
Bruce A. Wesner, CRL, is a Senior Managing Principal at Life Cycle Engineering.
