High voltage differential probes
The Elditest voltage differential probes make safe, accurate measurements between two voltage points where neither point is referenced to ground.
The Elditest voltage differential probes make safe, accurate measurements between two voltage points where neither point is referenced to ground. The probes offer input voltage of ±800 V, ±7.5 kV, or ±15 kV for both differential and common mode voltage, depending on the probe chosen. Compatible with oscilloscopes from all major manufacturers, the probes are ideal where high sensitivity and dynamic range is needed such as, precise power semiconductor device measurements, switching power supply design, measurement of converters, and precise measurement of motor drives.
Cal Test Electronics
www.caltestelectronics.com
