Heat tool kit
The UT-100-TC Ultratorch professional heat tool kit features a portable, butane-powered, multi-functional tool for use as a soldering iron, flames heat tool, hot knife and brazing torch. The kit includes three soldering tips, a hot-knife tip, a torch tip, and a hot air tip, along with a heat-shrink reflector, a wire cutter, needle nose pliers, a roll of 60/40 solder, a sponge, a cap and stand. The torch features adjustable temperature control for torch temperatures up to 2372 F, soldering temperatures up to 932 F and hot air temperatures up to1202 F. Master Appliance Corp.
Plant Engineering
Plant Engineering Staff
