Flextray cable management solution
The flextray cable management solution helps minimize labor and time on cable management installations.
The flextray cable management solution helps minimize labor and time on cable management installations. Flextray system is field-adaptable, making it simple to manage cables throughout most commercial and data center cable installation projects. The products feature a wire basket tray that can be easily cut and bent, allowing cable runs to be quickly adjusted on the jobsite. The wire basket accessories include a corner radius support, bottom and side drop outs, and blind ends.
Eaton
www.eaton.com
