Extended no-stop coupling options for the MegaPress and MegaPressG systems use cold press connections for pipe installation.
Viega’s extended no-stop coupling options for the MegaPress and MegaPressG systems are designed for joining schedule 5 to schedule 40 black iron pipe in sizes 1/2 to 2 in. The Viega MegaPress system uses cold press connections for pipe installation. The system is suited for hydronic heat, chilled water, compressed air, fire sprinkler systems, low-pressure steam, and vacuum lines. The fittings include elbows, couplings, reducers, reducing tees, threaded adapters, caps, flanges, and unions made with a stainless steel grip ring with an EPDM sealing element or HNBR. MegaPress system is UL, FM, and ASME B31 compliant for fire sprinkler, pressure, and boiler piping applications. MegaPressG fittings are CSA LC4 compliant for fuel gas and oil applications.
Viega
