Engineers develop efficient process to make fuel from carbon dioxide
The approach converts the greenhouse gas into formate, a solid fuel that can be stored indefinitely and could be used to power industries.
Energy efficiency insights
  • MIT and Harvard researchers developed an efficient process to convert carbon dioxide into stable, nontoxic formate, usable in fuel cells for emissions-free electricity generation with over 90% conversion efficiency.
  • Unlike traditional methods, this process achieves high carbon efficiency by directly converting CO2 into liquid metal bicarbonate, eliminating the need for inefficient heating, and producing a stable, easy-to-store formate powder for long-term use.
The search is on worldwide to find ways to extract carbon dioxide from the air or from power plant exhaust and then make it into something useful. One of the more promising ideas is to make it into a stable fuel that can replace fossil fuels in some applications. But most such conversion processes have had problems with low carbon efficiency, or they produce fuels that can be hard to handle, toxic, or flammable.
Researchers at MIT and Harvard University have developed an efficient process that can convert carbon dioxide (CO2) into formate, a liquid or solid material that can be used like hydrogen or methanol to power a fuel cell and generate electricity. Potassium or sodium formate, already produced at industrial scales and commonly used as a de-icer for roads and sidewalks, is nontoxic, nonflammable, easy to store and transport, and can remain stable in ordinary steel tanks to be used months, or even years, after its production.
The new process, developed by MIT doctoral students Zhen Zhang, Zhichu Ren, and Alexander H. Quinn; Harvard University doctoral student Dawei Xi; and MIT Professor Ju Li, is described this week in an open-access paper in Cell Reports Physical Science. The whole process — including capture and electrochemical conversion of the gas to a solid formate powder, which is then used in a fuel cell to produce electricity — was demonstrated at a small, laboratory scale. However, the researchers expect it to be scalable so that it could provide emissions-free heat and power to individual homes and even be used in industrial or grid-scale applications.
Other approaches to converting CO2 into fuel, Li explains, usually involve a two-stage process: First the gas is chemically captured and turned into a solid form as calcium carbonate, then later that material is heated to drive off the CO2 and convert it to a fuel feedstock such as carbon monoxide. That second step has very low efficiency, typically converting less than 20% of the gaseous carbon dioxide into the desired product, Li said.
By contrast, the new process achieves a conversion of well over 90 percent and eliminates the need for the inefficient heating step by first converting the CO2 into an intermediate form, liquid metal bicarbonate. That liquid is then electrochemically converted into liquid potassium or sodium formate in an electrolyzer that uses low-carbon electricity, e.g. nuclear, wind, or solar power. The highly concentrated liquid potassium or sodium formate solution produced can then be dried, for example by solar evaporation, to produce a solid powder that is highly stable and can be stored in ordinary steel tanks for up to years or even decades, Li said.
Rendering shows 3 parts as if on a grey table: a white model house on top; a fuel cell sandwiched in between two metal plates with spherical molecules floating around it; and on bottom is the electrolyzer, which looks similar to the fuel cell and has molecules floating around it.
Rendering shows 3 parts as if on a grey table: a white model house on top; a fuel cell sandwiched in between two metal plates with spherical molecules floating around it; and on bottom is the electrolyzer, which looks similar to the fuel cell and has molecules floating around it. Courtesy: Shuhan Miao, Harvard Graduate School of Design
Several steps of optimization developed by the team made all the difference in changing an inefficient chemical-conversion process into a practical solution, said Li, who holds joint appointments in the departments of Nuclear Science and Engineering and of Materials Science and Engineering.
The process of carbon capture and conversion involves first an alkaline solution-based capture that concentrates CO2, either from concentrated streams such as from power plant emissions or from very low-concentration sources, even open air, into the form of a liquid metal-bicarbonate solution. Then, through the use of a cation-exchange membrane electrolyzer, this bicarbonate is electrochemically converted into solid formate crystals with a carbon efficiency of greater than 96 percent, as confirmed in the team’s lab-scale experiments.
These crystals have an indefinite shelf life, remaining so stable that they could be stored for years, or even decades, with little or no loss. By comparison, even the best available practical hydrogen storage tanks allow the gas to leak out at a rate of about 1 percent per day, precluding any uses that would require year-long storage, Li said. Methanol, another widely explored alternative for converting CO2 into a fuel usable in fuel cells, is a toxic substance that cannot easily be adapted to use in situations where leakage could pose a health hazard. Formate, on the other hand, is widely used and considered benign, according to national safety standards.
Several improvements account for the greatly improved efficiency of this process. First, a careful design of the membrane materials and their configuration overcomes a problem that previous attempts at such a system have encountered, where a buildup of certain chemical byproducts changes the pH, causing the system to steadily lose efficiency over time. “Traditionally, it is difficult to achieve long-term, stable, continuous conversion of the feedstocks,” Zhang said. “The key to our system is to achieve a pH balance for steady-state conversion.”
To achieve that, the researchers carried out thermodynamic modeling to design the new process so that it is chemically balanced and the pH remains at a steady state with no shift in acidity over time. It can therefore continue operating efficiently over long periods. In their tests, the system ran for over 200 hours with no significant decrease in output. The whole process can be done at ambient temperatures and relatively low pressures (about five times atmospheric pressure).
Another issue was that unwanted side reactions produced other chemical products that were not useful, but the team figured out a way to prevent these side reactions by the introduction of an extra “buffer” layer of bicarbonate-enriched fiberglass wool that blocked these reactions.
An electrolzyer configuration with a bicarbonate cathode, intermediate buffer layer, cation exchange membrane and a water anode.
An electrolzyer configuration with a bicarbonate cathode, intermediate buffer layer, cation exchange membrane and a water anode. Courtesy: Shuhan Miao, Harvard Graduate School of Design
The team also built a fuel cell specifically optimized for the use of this formate fuel to produce electricity. The stored formate particles are simply dissolved in water and pumped into the fuel cell as needed. Although the solid fuel is much heavier than pure hydrogen, when the weight and volume of the high-pressure gas tanks needed to store hydrogen is considered, the end result is an electricity output near parity for a given storage volume, Li said.
The formate fuel can potentially be adapted for anything from home-sized units to large scale industrial uses or grid-scale storage systems, the researchers say. Initial household applications might involve an electrolyzer unit about the size of a refrigerator to capture and convert the CO2 into formate, which could be stored in an underground or rooftop tank. Then, when needed, the powdered solid would be mixed with water and fed into a fuel cell to provide power and heat.
“This is for community or household demonstrations,” Zhang said, “but we believe that also in the future it may be good for factories or the grid.”
David L. Chandler
MIT News Office
