Dual laser infrared thermometer
The IR2000A thermometer has 6.6 ft. drop protection, dual laser targeting, tight distance-to-spot ratio, a wide temperature measurement range, and auto temperature scan.
Klein Tools’ IR2000A 12:1 dual laser infrared thermometer measures the temperature of transformers, motors, compressors, ducts, electrical circuits, valves, vents, etc. The IR2000A is a dual laser infrared thermometer that provides a more confident indication of the circumference of measurement than a single laser gun. With dual lasers, the gun measures the temperature of a circular area that falls between the two laser points, providing a clear measurement area. It has drop protection of up to 6.6 ft.
IR2000A comes with dual laser targeting¸ tight distance-to-spot ratio, a wide temperature measurement range, auto temperature scan, 6.6 ft. drop protection, Fahrenheit or Celsius readings, a K-type thermocouple, backlit display, work light, auto power off, and several sampling modes.
Klein Tools
https://www.kleintools.com
