Digital compact Ethernet module
These modules are a machine-mountable solution for connecting industrial controllers to I/O devices in harsh-duty environments.
These modules are a machine-mountable solution for connecting industrial controllers to I/O devices in harsh-duty environments. 30mm housings are well-suited to compact machines where space is limited.  The I/O channels can be individually configured as inputs or outputs with M8 or M12 connectors for attaching sensing devices or actuators.
Featuring an IP67-rated housing to resist dust, liquid and vibration, on-machine mounting of the module eliminates the need for a protective cabinet.  The daisy-chain wiring topology and integrated 2-port switch with 100 Mbps full duplex data transmission enables an application to be wired without switches.
Molex Incorporated
www.molex.com
