Crane mounted welder has mobility
Wall Crane Welding Machine with pushbutton control can be positioned with a wire feed assembly anywhere -- both horizontally and vertically -- along a fabrication bay. All welding controls are at the wire feed, which is within easy reach.
Wall Crane Welding Machine with pushbutton control can be positioned with a wire feed assembly anywhere — both horizontally and vertically — along a fabrication bay. All welding controls are at the wire feed, which is within easy reach. The welder always has a choice of two wire sizes or stick welding. A ground fault protected 115-V outlet provides a convenient source of power for tools.
Stewart Engineering & Sales Co.
www.steweng.com
Circle 384
