Continuous vertical lift
The model 180 high-speed continuous vertical lift is designed to accept loads horizontally, convey them vertically and discharge them horizontally in a “Z” pattern.
The model 180 high-speed continuous vertical lift is designed to accept loads horizontally, convey them vertically and discharge them horizontally in a “Z” pattern. The lift runs in a single vertical direction — up or down — or can be configured to be reversible on-demand. The chain driven system features a 6,000-pound unit-load capacity and with a chain speed of up to 120 feet per minute, and will deliver up to 35 loads per minute depending on product dimensions. No operator intervention is required except for routine maintenance.
TKF Inc ., www.TKF.com
Plant Engineering Staff
