Emerson Process Management's Rosemount CT5100 continuous gas analyzer combine tunable diode laser (TDL) and quantum cascade laser (QCL) measurement technologies for process gas analysis and emissions monitoring.
Emerson Process Management’s Rosemount CT5100 continuous gas analyzer combine tunable diode laser (TDL) and quantum cascade laser (QCL) measurement technologies for process gas analysis and emissions monitoring. The CT5100 can measure up to 12 critical component gases and potential pollutants simultaneously within a single system. The CT5100 operates with no consumables, no in-field enclosure, and a simplified sampling system that does not require any gas conditioning to remove moisture. The new gas analyzer is ideally suited for process gas analysis, continuous emissions monitoring, and ammonia slip applications. It uses a laser chirp technique designed to expand gas analysis in both the near- and mid-infrared range, enhancing process insight, improving overall gas analysis sensitivity and selectivity, removing cross interference, and reducing response time. The laser chirp technique produces well-defined peaks from high resolution spectroscopy that enable specificity of identified components with minimum interference and without filtration, reference cells, or chemometric manipulations.
– Edited by CFE Media. See more Control Engineering process sensor and actuator products.
