Hydraulic Fluids, A Guide to Selection, Test Methods, and Use is a concise reference to most of the fluids used in plant hydraulic and lubricating systems. A better understanding and proper care of hydraulic fluids is very important for performance as well as for economic considerations. This book covers a broad spectrum of hydraulic fluids.
This book covers a broad spectrum of hydraulic fluids. For easy reference and detailed treatment, the subject is covered in nine chapters. There is a detailed treatment of mineral oils; the most extensively used hydraulic fluid. As most of the properties covered are also applicable to other lubricants, readers will find this book very useful.
A conscious effort has been made to include all relevant tests relating to hydraulic fluids. High water content fluids (HWCF) are covered in a separate chapter without being grouped with fire-resistant fluids. Many readers still consider using HWCF as a replacement for mineral oils rather than as a fire-resistant fluid.
Maintenance, an important component of any hydraulic system, often is not appreciated in practice. In the case of hydraulic fluids, it helps not only to extend the longevity of the fluid but also associated equipment. A comprehensive treatment on the maintenance of all hydraulic fluids is presented.
Improper used oil disposal and its impact on the environment has drawn the attention of many countries and disposal of used oil is being regulated through state legislation. To emphasize these important socioeconomic aspects, a chapter is devoted to disposal, regulations, and used oil recycling.
Data sheets on commercially available anti-wear mineral oils, fire-resistant fluids, and biodegradable fluids serve as a handy reference to readers for the selection as well as the application of hydraulic fluids. They are also helpful in understanding the specifications and properties of hydraulic fluids.
Hydraulic Fluids, A Guide to Selection, Test Methods, and Use by M. Radhakrishnan is published by the American Society of Mechanical Engineers, Three Park Ave., New York, NY 10016; 212-591-7000.
