Water-based flooring system
AquArmor flooring systems are engineered using a water-based resin technology and offer 100 times the permeability of standard epoxy floor systems. It can be used underneath most flooring, including terrazzo and resinous floors, or as a standalone system. The low-odor flooring system has zero VOCs and can be applied to green concrete without taking moisture readings.
The Sherwin-Williams Co. : www.sherwin-williams.com/im
