Ametek Drexelbrook's total tank level measurement system incorporates magnetostrictive sensing technology and multi-variable functionality and is designed for oil and gas, chemical and petrochemical storage tank and inventory control applications.
Ametek Drexelbrook’s total tank level measurement system incorporates
magnetostrictive sensing technology and multi-variable functionality. The system features five temperature sensor outputs distributed over the active length of the system’s polymer and stainless steel probe. The probe is available in lengths up to 50 ft and is also available in a 316 stainless steel version. The system’s explosion-proof design and welded construction make it useful for oil and gas, chemical and petrochemical storage tank and inventory control applications. The system’s digital Modbus output measures total level, interface level and temperature from an explosion-proof housing. The system meets FM and FMc hazardous area approvals and requires minimal maintenance. A variety of floats and mounting accessories are available and the probes are offered with a choice of single or dual NPT mountings.
Ametek Drexelbrook
– Edited by CFE Media. See more Control Engineering process sensor and actuator products.
