Steam turbine seals
The GTS steam seal for general purpose impulse steam turbine applications is described in a 4-p brochure.
The GTS steam seal for general purpose impulse steam turbine applications is described in a 4-p brochure. The literature explains how the seal — intended to replace split carbon ring seals — is used to retrofit existing turbines with a minimum of equipment modification.
Flowserve Corp.
Circle 344
