Simple Solutions – 2001-06-01
Making connections Problem: Pushing a male air line quick-connect into its mate can be difficult using only finger friction on the air hose, especially when the hose or hands are oily. Is there a way to make this connection? Solution: Before installing the quick-connect on the hose, place an appropriate sized washer on the hose behind the fitting and clamp.
Making connections
Solution: Before installing the quick-connect on the hose, place an appropriate sized washer on the hose behind the fitting and clamp. A “fender” washer is ideal because of its large surface area, although the hole in the washer may need some enlarging. When the hose is clamped on the fitting, the swelling captures the washer, if the fit is snug. The washer provides a generous surface to push against and overcome the spring tension in the female connector.
On hoses with pipe thread fittings, the washer can be captured between the pipe nipple threads and the male disconnect fitting. Use a washer that fits snugly over the threads.
Contributor: Rob Herklotz, Mechanical Technologist, Saturn Corp., G.M.C., Spring Hill, TN
Removing oil seals
Problem: How is a pressed-in oil seal easily removed from a gearbox or housing, with or without the shaft installed, when it is inaccessible from the backside?
Solution: Carefully center punch the seal at the 3:00, 6:00, 9:00, 12:00 o’clock positions. Drill small holes through the seal at each location. Using an automotive slide hammer (dent puller with a small screw on the tip), pull the seal out slowly and squarely, alternating between all four holes.
Be careful not to drill too deeply or screw the tip in too far since either case will damage the shaft, housing, or bearing. Also remember to thoroughly clean up the drill chips and shavings prior to reassembly.
Contributor: Tim Mostowy, Ervin Industries, Tecumseh, MI
Combining wire nuts and tape
Problem: Electrical connections with wire nuts sometime loosen, get hot, or lose contact over time. Is there a way — short of soldering the wires together — to keep them tight, yet easily taken apart when necessary?
Solution: First, make sure the wires are secure by using the proper size wire nut. After tightening, cover the wire nut with a couple wraps of electrical tape installed in the same direction as the nut was tightened. Extend the tape down and around the connected wires.
This approach keeps the wires tight, better insulated, troublefree, and easily removed when time to take them apart.
Contributor: Phil Bard, Parker Hannifin, Albion, IN
