Oil seal also isolates bearings
STS oil seal doubles as a bearing isolator on many types of rotating equipment, such as double reduction gear boxes, worm gears, externally lubricated pumps, and sleeve bearing motors.
STS oil seal doubles as a bearing isolator on many types of rotating equipment, such as double reduction gear boxes, worm gears, externally lubricated pumps, and sleeve bearing motors. Standard oil seals allow lubricant to collect on the exterior of equipment, which creates a constant lube loss.
Inpro/Seal Co.
Circle 387
