Continue to Site
OEM controller with sensor range for control applications
Micronor's MR380-0 OEM controller is designed to provide a turn-key solution for original equipment manufacturers (OEM) and control system providers and is designed for medical, transportation, and industrial applications.
By Micronor May 18, 2016
Micronor’s MR380-0 OEM controller is designed to provide a turn-key solution for original equipment manufacturers (OEM) and control system providers. It integrates any of the Micronor MR38X series zapfree fiber optic signaling sensors into the product. The sensor range includes emergency stop, E-actuator U-beam, key switch, pushbutton, foot switch, and microswitch sensors. The OEM Controller contains a stable transmitter and a sensitive optical receiver, which operate over a Duplex LC multimode fiber optic link. The transmitter sends a constant light level via the transmit fiber which is interrupted when the fiber optic switch activates or the sensor beam is broken. The controller operates over a wide 5 to 24 Vdc range and provides a digital logic as well as open-collector output for activating external relays. Applications include medical and MRI; transportation; oil, gas, and mines; petrochemical plants; high voltage transformer and switch gear; fire suppression systems; and process industries and instrumentation.
Micronor
www.micronor.com
– Edited by CFE Media. See more Control Engineering PLC and PAC products.
