Network device
The Series 24 Serial Lock-Out Relay, which is certified DNP 3.0 protocol, provides remote trip and reset capability, trip-coil monitoring, IRIG-B sequence-of-events reporting, system battery monitoring, self-diagnostic reporting and two auxiliary monitoring inputs.
The Series 24 Serial Lock-Out Relay, which is certified DNP 3.0 protocol, provides remote trip and reset capability, trip-coil monitoring, IRIG-B sequence-of-events reporting, system battery monitoring, self-diagnostic reporting and two auxiliary monitoring inputs. The unit frees up remote terminal unit points, which reduces wiring and simplifies load-shedding applications while minimizing testing needs. Rated 30A/600 V continuous with a circuit-breaker coil making ability of 95 A,125 Vdc, the unit’s UL interrupt ratings are 20 A, 120 Vac; 15A, 240 Vac; 6 A, 600 Vac; 3 A, 125 Vdc; and 1 A, 250 Vdc.
Electroswitch
www.electroswitch.com
Plant Engineering Staff
