MC series of magnetic catches by FDB Panel Fittings
The catches are designed for sheet metal applications and can be used in furniture production.
At less than 3mm thick it is an easy to fit closure device which does not disrupt the integrity of your design. Perfect for sheet metal applications it can also be utilized in furniture production where the ample 4kg force will keep large doors closed.
FDB Panel Fittings Ltd
Home
View this product in the New Products for Engineers Database.
FDB Panel Fittings are specialists in the supply of industrial access hardware (enclosure locks, hinges, handles and accessories) for the metal/plastic fabrication industry, panel builders and OEMs. Applications include cabinets, enclosures, electrical/electronic panels and racks, as well as HVAC equipment panels and furniture, sealing capability from IP40 to IP66 possible. Many are available in Stainless Steel 303, 304 or 316. In addition FDB offer a comprehensive assembly and logistics package under the Rocfast brand which takes customers through specification of locks and other hardware to packaging and delivery e.g. in production sets to factory or installation site to an agreed program. Products types include: budget locks, camlocks, compression locks, knob locks, rod locks, spanner locks, waterproof locks, combination locks, quarter-turn locks, pin tumbler locks, furniture locks, toggle latches, concealed hinges, flush hinges, butt hinges, lift-off hinges, 'piano' hinges, stainless hinges, weld-on hinges, block hinges, continuous hinges, torque hinges, panel hinges, earth bars/busbars, flush handles, padlockable handles, telescopic stays, wind stops, door seals and profiles, drawing holders, gas struts, grab handles, lever handles, tee handles, paddle handles, padlocks, support stays, seals/gaskets, blind rivets, riveting tools, riveting accessories.
