Laser alignment system simplifies operation
Rotalign Pro alignment system is water, shock, and dust-proof. Just enter dimensions, rotate the shaft in one continuous sweep less than 1/4 turn from any starting position, and view results at the coupling and feet.
Rotalign Pro alignment system is water, shock, and dust-proof. Just enter dimensions, rotate the shaft in one continuous sweep less than 1/4 turn from any starting position, and view results at the coupling and feet. Built-in angle sensor eliminates the need for readings at clock positions.
Ludeca, Inc.
www.ludeca.com
