Parker Hannifin's AHL118 is a high-volume, double-ended, double acting high pressure liquid pump that is designed for use in oil and gas, chemical, industrial, and research applications.
Parker Hannifin’s AHL118 is a high-volume, double-ended, double acting high pressure liquid pump that is designed for use in oil and gas, chemical, industrial, and research applications. The pump operates to a pressure range of 23,000 psi and at 5.6 gallons per minute (gpm) The AHL118 is designed to be extremely robust, featuring a carbon-based prioritized coating to the plunger. This makes the plunger unscratchable, extending the lifespan of the seals and reducing downtime, repairs and servicing, delivering major savings to the customer. All of the AHL118’s hydraulic parts are manufactured from stainless steel, making them very durable with extended mean time between maintenance (MTBM) and increasing safety. All AHL118’s pump hardware is manufactured from stainless steel, which is anodized to the bottom and top caps for superior corrosion resistance.
Parker Hannifin Corporation
www.parker.com
– Edited by CFE Media. See more Control Engineering process sensor and actuator products.
