Digital panels
ProSense line of digital panels is a cost-effective solution to display analog process, temperature, load cell, and potentiometer inputs.
ProSense digital panel meters are designed to display analog process signals, including +/-10 V and +/-20 mA. The 4-digit red LED display is easily scaled into any engineering units from -1999 to 9999 with a selectable decimal point location. Non-linear processes can be scaled by entering up to 16 scaling points. It offers two SPST relay outputs that can be set to activate on an increasing or decreasing input signal with hysteresis or time delay operation, retention and reset of minimum and maximum display values, a tare function, filtering to minimize display bounce, and display brightness adjustment.
AutomationDirect
www.automationdirect.com
AutomationDirect
