Cube evaporative condenser models
The Cube™ Evaporative Condenser product line is ideal for industrial refrigeration applications that require safe design, installation, and operation with ammonia and other refrigerants.
The Cube™ Evaporative Condenser product line is ideal for industrial refrigeration applications that require safe design, installation, and operation with ammonia and other refrigerants. Cube Evaporative Condensers were designed to simplify field installation, with easy alignment of top and bottom modules, minimal fasteners, and pre-assembled platform and guardrail options. Increased accessibility to both external and internal components helps speed routine inspection and maintenance. Cube Evaporative Condensers are available in both forced draft/blow through (BTC) and induced draft/draw through (DTC) models.
SPX Cooling Technologies
www.spxcooling.com
