Compact Ethernet switch for industrial applications
Siemens' Ruggedcom RSG920P is a high port density Ethernet switch designed to withstand extreme temperature, vibration, and shock in industrial applications such as transportation systems and oil and gas.
Siemens’ Ruggedcom RSG920P is a high port density Ethernet switch designed to withstand extreme temperature, vibration, and shock in industrial applications such as transportation systems and oil and gas. With 20 Gigabit Ethernet ports, the Ruggedcom RSG920P is suitable for applications that require high bandwidths and is ready to accommodate future network expansions. Four SFP (small form factor pluggable) slots provide flexibility in uplink distances and bandwidth options with support for Gigabit as well as Fast Ethernet fiber SFPs. The small form factor of the Ruggedcom RSG920P provides the capacity of a 19-in. switch and allows deployment in space limited cabinets. The Micro SD card slot allows the user to store application data, firmware, and device configuration for commissioning and field maintenance. Other features include four Power-over-Ethernet (PoE) interfaces supplying up to 120 W (30 W per port) of power. The Ruggedcom RSG920P can accommodate various PoE devices such as pan-tilt-zoom (PTZ) cameras, intercom devices, Wireless LAN access points and Bluetooth sensors.
Siemens Industry Inc.
usa.siemens.com
– Edited by CFE Media. See more Control Engineering Ethernet products.
