Centrifugal pump reduces membrane fouling
The 200MS Series high-pressure multistage centrifugal pump is used for recirculating service in reverse osmosis and other membrane systems.
The 200MS Series high-pressure multistage centrifugal pump is used for recirculating service in reverse osmosis and other membrane systems. The pumps are equipped with a balanced, double-shaft seal with buffer fluid ports on top and bottom for removal of air/vapor from the seal chamber. Constant flow reduces reverse osmosis membrane fouling.
Waukesha Cherry-Burrell
