Boilers and water heaters
Recent enhancements made to the line of low NOx KC1000 high-efficiency boilers and water heaters support sealed combustion and can be configured to support dual-fuel (natural gas or propane) applications. The units will not require seasonal combustion air recalibration in applications where ambient air temperatures remain between -30 and 130 degrees F.
Recent enhancements made to the line of low NOx KC1000 high-efficiency boilers and water heaters support sealed combustion and can be configured to support dual-fuel (natural gas or propane) applications. The units will not require seasonal combustion air recalibration in applications where ambient air temperatures remain between -30 and 130 degrees F. The low NOx boiler and water heaters will be shipped with a replacement spring for the unit’s differential regulator, which also supports the switch from one fuel type to the other. Using natural gas, the units maintain low NOx emissions over their entire 11:1 operating range. Whether a unit is initially configured for natural gas or propane, the part retrofit and combustion air recalibration can be performed in a matter of minutes.
Aerco
www.aerco.com
