Antistatic power transmission belt
The Poly Chain Carbon Volt belt is engineered to reduce safety risks in explosive environments by providing longer-lasting static conductivity.
The Poly Chain Carbon Volt belt is an antistatic polyurethane solution that meets the ISO 9563 spec and retains its static conductivity longer than comparable belts.
Poly Chain Carbon Volt belts are designed for use in volatile environments like oil and gas refineries, chemical processing plants, and grain silos, the Poly Chain Carbon Volt belt features static-conductive fibers that safely transfer static to carbon tensile cords and away from the driven side of a power transmission application for improved safety in unstable settings.
The belts offer increased safety along with the opportunity for higher horsepower, reduced drive size, and lower component costs.
Gates Corporation
gates.com/volt
