The AMI motorized axial fans are suited for applications where space is limited and features 115 or 230 VAC single phase 60 Hz operation.
The AMI motorized axial fans are suited for applications where space is limited and features 115 or 230 VAC single phase 60 Hz operation. The fans are speed controllable and both motor and impeller are located directly in the air stream, where the impeller acts as a rotating "heat sink" with heat dissipation and motor cooling. The motorized fans have a temperature range of -40 F to 158 F. The coupling of motor and impeller minimizes space requirements and provides for vibration free operation.
Continental Fan
