3-phase power conditioner
The Sola/Hevi-Duty Solatron Plus 3-Phase Power Conditioner protects against common power quality problems by providing true voltage regulation, surge protection, and noise isolation - even through inductive and poor power factor loads. Within an input voltage range of -25% to +15%, the Solatron Plus produces an output voltage of less than +/-5% of nominal voltage regulation to maintain as stabl...
The Sola/Hevi-Duty Solatron Plus 3-Phase Power Conditioner protects against common power quality problems by providing true voltage regulation, surge protection, and noise isolation – even through inductive and poor power factor loads. Within an input voltage range of -25% to +15%, the Solatron Plus produces an output voltage of less than +/-5% of nominal voltage regulation to maintain as stable, smooth power for critical processes and production. Common voltage configurations available from stock are 20, 30, 50 and 75 KVA in combinations of 208, 480 and 600 Volt offerings.
Sola/Hevi-Duty www.solaheviduty.com
