VT Series Vacuum Tube Lifter features articulating pads that adjust to contoured surfaces and an extended handle for use with bulky loads up to 450 lb.
VT Series Vacuum Tube Lifter features articulating pads that adjust to contoured surfaces and an extended handle for use with bulky loads up to 450 lb. Available with a full range of pads for handling smooth and wavy to rough surfaces, the unit provides a 100% duty cycle for continuous operation. Power pack, 360-deg vacuum-tight swivel, and wire-reinforced hose are standard.
Anver Corp.
www.anver.com
Circle 375
