An ergonomic, two-handed start solution keeps the operator’s hands away from rotating spindles and pinch points while using DC nut runners, particularly tube nuts. A low-force, spring-loaded sleeve with a second switch allows the operator to grip the tool comfortably in varying orientations. Both switches must be actuated within 500 meters for the tool to start.
An ergonomic, two-handed start solution keeps the operator’s hands away from rotating spindles and pinch points while using DC nut runners, particularly tube nuts. A low-force, spring-loaded sleeve with a second switch allows the operator to grip the tool comfortably in varying orientations. Both switches must be actuated within 500 meters for the tool to start. The option is available on any E23L through E55L QPM model.
Stanley Assembly Technologies
www.StanleyAssembly.com
