Temperature datalogger
The OM-CP-TEMP1000FP is a rugged, waterproof, portable, battery powered, stand-alone high temperature recorder and is easy to use. This all-in-one compact device records up to 32,767 measurements at -40° to 150°C (-40° to 302°F) temperature range. The datalogger is ideal for use in harsh environments.
The OM-CP-TEMP1000FP is a rugged, waterproof, portable, battery powered, stand-alone high temperature recorder and is easy to use. This all-in-one compact device records up to 32,767 measurements at -40° to 150°C (-40° to 302°F) temperature range. The datalogger is ideal for use in harsh environments. Its real time clock ensures that all data is date and time stamped. Retrieve data simply by plugging the logger into the COM port of a computer. Data can be printed in a graphical and tabular format or exported to a text or Microsoft Excel file. If the battery becomes discharged, the logger’s non-volatile memory retains the data until the battery is replaced.
Omega
www.omega.com
