Synchronous motors
The 8LT Series three-phase synchronous motors are virtually maintenance-free and help eliminate the need for angular gears. The synchronous motors are available in two sizes with self-cooled and externally cooled options. The supply voltage of the high-torque motors ranges from 400-480 Vac, with a rated power of 0.
The 8LT Series three-phase synchronous motors are virtually maintenance-free and help eliminate the need for angular gears. The synchronous motors are available in two sizes with self-cooled and externally cooled options. The supply voltage of the high-torque motors ranges from 400-480 Vac, with a rated power of 0.11-21 kW. The synchronous motors feature an embedded parameter chip that identifies device data such as serial number, manufacturer data and type.
B&R Industrial Automation Corp.
www.br-automation.com
Plant Engineering Staff
