Industry trend talk: Using steam tracing for process
Heat tracing can be used to heat a variety of products. Understanding the basics of sizing and installing external line tracing will help you apply it effectively.
06/10/2015
Often, the temperature of process liquids being transferred through pipelines must be maintained to meet process requirements, prevent thickening and solidification, or simply to protect against freeze-up. This is achieved with jacketed pipes or by attaching one or more tracing lines (carrying a heating medium such as steam or hot water) to the product’s pipeline. In these applications, steam usage may be relatively small, but the tracing system usually is a major component of the steam installation and the source of many problems.
While no single article can address all of the contingencies affecting a steam tracing system, the following guidelines provide an overview of items to consider. Only external tracing is addressed because this is the area most likely to cause difficulties when no existing experience is available. External tracing is simple, and, therefore, inexpensive to install and fulfills the most processes’ needs.
External tracer lines
One or more heat-carrying lines, sized from 0.375 to 1 in. normal bore, are attached to the main product pipe. Heat transfers to the product in three ways: conduction – through direct contact, convection, via currents in the air pocket formed in the insulating jacket, and through radiation. Tracer lines can be constructed of carbon steel, copper or stainless steel. If the product line is constructed of a particular material to accommodate the process fluid, the tracer line material must be selected carefully to avoid electrolytic corrosion at contact points.
Figure 1: Small bore tracing lines can be wrapped around vertical product lines, but this method should not be used on long, horizontal runs. Courtesy: Spirax SarcoFor short tracing runs – around short vertical pipes or valves and fittings – small bore copper pipes (perhaps 0.25 in. bore) may be wound around the product lines (figure 1). The layout should be arranged to provide a continuous fall along the tracers. (Note: Wrap around tracers should be avoided on long horizontal lines.) A run of even 100 ft of 6 in. product line will require 500 to 600 ft of wrap-around tracing. In this scenario, the pressure drop along the tracer would be high and the temperature at the end of the line away from the supply would be low. Indeed, the remote end of the tracer probably would contain only condensate, and the water’s temperature would fall as it continued to give up heat.
Clip-on tracers
The simplest form of external tracer is clipped or wired to the product line. Maximum heat flow is achieved when the tracer is in tight contact with the product line; consequently, the securing clips should not be spaced wider than 12 to 18 in. on 03.75 in. tracers; 18 to 24 in. on 0.5 in. tracers; and 24 to 36 in. on 0.75 in. and larger tracers.
The tracer pipes literally can be wired on, but to maintain close contact, 0.5 in. galvanized or stainless steel bands are better. One practical application method is a packing case banding machine. Where racers are carried around bends, three or more bands should be used to ensure that good contact is maintained. Where it is not possible to use bands as on valve bodies often annealed stainless steel 18 gauge wire is an alternative. With either band material, remember to consider any special needs to avoid external corrosion or electrolytic action.
Welded tracers
Where the temperature difference between the tracer and the product is low, the tracer can be welded to the product line. This can be done either with short-run welds or with a continuous weld for maximum heat transfer. Welded tracer sometimes is laid along the top of the pipe instead of the bottom, greatly simplifying installation. Advocates of this method claim that the location does not adversely affect heat transfer rates.
Figure 2: Heat conducting paste can be placed in the air gap to improve heat transfer. Courtesy: Spirax SarcoHeat conducting paste
For maximum heat transfer, a heat conducting paste can be used to fill the normal hot air gap (figure 2). The paste can be used with any of the clipping methods, but the surface must be wire-brushed clean before applying the past.
Insulation
If the product being heated is temperature sensitive, it is important to avoid local hot spots on the pipe by introducing a strip of insulation material – fiberglass or mineral wood with packing blocks constructed of inert material to maintain spacing – between the tracer and the product pipe.
Insulation should be used over the tracer line and product pipeline. Three basic methods are used: Aluminum foil (A); preformed, sectional insulation (B); and preformed, sectional molded insulation (C).Insulation should be used over the tracer line and product pipeline. Three basic methods are used: Aluminum foil (A); preformed, sectional insulation (B); and preformed, sectional molded insulation (C).In every installation, insulation should cover both the product line and tracer, but the air space must remain clear. This can be achieved three ways (figure 3)
  • Aluminum foil or galvanized steel sheet can be wrapped around the line and tracing; then, insulation is applied over the sheet or foil. Alternatively, small mesh galvanized wire netting can be used instead of metal sheet.
  • Sectional insulation preformed to one or two sizes larger than the product main can be used. One disadvantage is this insulation can be easily crushed.
  • Preformed sectional insulation designed to cover both product line and tracer can be used. Preformed rigid sectional insulation usually is preferred to plastic material because – rigid insulation retains its thickness and efficiency.
In all cases, the insulation should be finished with waterproof covering: Most insulation is porous, and it is useless as heat-conserving material if it is allowed to absorb water. It also may need to be protected from mechanical damage.
October 2018
September 2018
July/Aug
October 2018
August 2018
October 2018
September 2018
