Hydrolert detects water in lubricating oils before damaging levels are reached, which extends bearing and gear life. Until a visual indication is made, the equipment's lubricant is assumed to be uncontaminated by moisture.
Hydrolert detects water in lubricating oils before damaging levels are reached, which extends bearing and gear life. Until a visual indication is made, the equipment’s lubricant is assumed to be uncontaminated by moisture. The device works well with all forms of lubricants, including synthetic oils. It requires no external power supply and has a 3-yr battery life.
Trico Mfg. Co.
www.tricomfg.com
Circle 385
