Pressure gauge
The Series DM-1000 DigiMag digital differential pressure gauge is able to be field-programmed to display eight commonly used engineering units as well as percent of full scale. This capability allows quick units selection on site, eliminating the need to calculate various unit conversions. Programming the Series DM-1000 is easy using the menu key to access 4 simplified menus which provide acces...
The Series DM-1000 DigiMag digital differential pressure gauge is able to be field-programmed to display eight commonly used engineering units as well as percent of full scale. This capability allows quick units selection on site, eliminating the need to calculate various unit conversions. Programming the Series DM-1000 is easy using the menu key to access 4 simplified menus which provide access to: security level; digital damping for smoothing erratic process applications; display update to conserve battery life; zero and span for field calibration.
Dwyer Instruments www.dwyer-inst.com
