Precision metering system
The Servo-Flo 704-HV is a high-volume, continuous-flow, dual-gear metering system that precisely proportions, mixes and dispenses infinite volumes of two-part epoxies, polyurethanes, silicones and acrylics.
The Servo-Flo 704-HV is a high-volume, continuous-flow, dual-gear metering system that precisely proportions, mixes and dispenses infinite volumes of two-part epoxies, polyurethanes, silicones and acrylics. Its dual-servomotor design provides fixed and variable-flow-rate dispensing or variable-flow-rate profiling, which varies the dispense rate, on-ratio, during filling operations for optimum part quality and production cycle time. The system selects a preset dispense program, which adjusts material-volume settings and output flow rates for different sized part batches or extruded bead sizes. The system, control panel and supply can be frame-mounted, portable-cart mounted or enclosed with accessories. Sealant Equipment & Engineering, Inc. www.sealantequipment.com
